Hello. Are any examples available for setting the xamMap mapLayer shapefile source as well as defining the projection coordinates using the MVVM pattern? Rather than setting these values in the XAML or view I'd like to set them in the viewModel.
<igMap:MapLayer Brushes="#661E90FF"> <igMap:MapLayer.Reader> <igMap:ShapeFileReader Uri="c:\shapefile\district"> <igMap:ShapeFileReader.CoordinateSystem> <igMap:CoordinateSystem FalseEasting="1000000" FalseNorthing="1000000" > <igMap:CoordinateSystem.Projection> <igMap:LambertConformalConic EllipsoidType="GRS1980" CentralMeridian="-100" StandardParallelNorth="27.41" StandardParallelSouth="34.91" LatitudeOrigin="31.16" /> </igMap:CoordinateSystem> </igMap:ShapeFileReader.CoordinateSystem> </igMap:ShapeFileReader> </igMap:MapLayer>
Thanks.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
Thank you for your post. I have been looking into it and I have created a sample application for you, that shows how you can use binding to implement the XamMap’s ShapefileReader. I have created an instance of the ViewModel in the Resources of the XamMap’s parent and use it as a Source of the binding, since the ShapefileReader class, does not derive from FrameworkElement and does not supports DataContext.
Please let me know if you need any further assistance on the matter.
