Does this support Drag and drop within 2 different List Boxes as well within a Listbox as well. My use case is i would want to change ordering of items on my listbox as well as drag and drop from another listbox as well. Is there a sample you could provide to demo this capability.
Cheers,
Raul
HI,
Here is a new sample that will allow drop when the ListBox is empty.
Sincerely, Matt Developer Support Engineer
Hi Matt,
I was able to extend it to bidirectional drag and drop, however the challenge is when I drag off all items from one listbox to another I cannot add them back.
I am attaching a new sample that does bi-directional drag and drop.
Sincerely,
Matt
Thanks for this, I was able to extend yr sample to cover all my use cases. However when I drag all items from Listbox A onto ListBox B, after that I was unable to drag back items onto Listbox A.
<Window x:Class="WpfApplication209.MainWindow" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:vm="clr-namespace:WpfApplication209.ViewModel" xmlns:ig="http://schemas.infragistics.com/xaml" Title="MainWindow" Height="350" Width="525"> <Grid DataContext="{StaticResource vm}"> <Grid.Resources> <DataTemplate x:Key="dt"> <Rectangle Fill="red" Width="14" Height="15"/> </DataTemplate> </Grid.Resources> <Grid.ColumnDefinitions> <ColumnDefinition Width="100"/> <ColumnDefinition Width="auto"/> </Grid.ColumnDefinitions> <ListBox ItemsSource="{Binding People}" Grid.Column="0"> <ListBox.ItemTemplate> <DataTemplate> <StackPanel Orientation="Horizontal" > <ig:DragDropManager.DragSource> <ig:DragSource DragChannels="a,b" DragTemplate="{StaticResource dt}" DragStart="DragSource_DragStart" Drop="DragSource_Drop" IsDraggable="True"/> </ig:DragDropManager.DragSource> <ig:DragDropManager.DropTarget> <ig:DropTarget DropChannels="b" IsDropTarget="true"/> </ig:DragDropManager.DropTarget> <TextBlock Margin="0,0,3,3" Text="{Binding Name}"/> <TextBlock Text="{Binding State}"/> </StackPanel> </DataTemplate> </ListBox.ItemTemplate> </ListBox> <ListBox ItemsSource="{Binding Choosen}" Grid.Column="1" MinWidth="100"> <ListBox.ItemTemplate> <DataTemplate> <StackPanel AllowDrop="True" Orientation="Horizontal" > <ig:DragDropManager.DragSource> <ig:DragSource DragChannels="b" DragStart="DragSource_DragStart" Drop="DragSource_Drop" IsDraggable="True"></ig:DragSource> </ig:DragDropManager.DragSource> <ig:DragDropManager.DropTarget> <ig:DropTarget DropChannels="a" IsDropTarget="true"/> </ig:DragDropManager.DropTarget> <TextBlock Margin="0,0,3,3" Text="{Binding Name}"/> <TextBlock Text="{Binding State}"/> </StackPanel> </DataTemplate> </ListBox.ItemTemplate> </ListBox> </Grid> </Window>
I am attaching an Inter and Intra Listbox Drag and Drop Application.
