I have an issue with the XamDataGrid.
I add the Fields dynamically to the XamDataGrid and I want the customer to be able to use the summary option Sum (Sigma sign in the header of the field).
This goes well if I use a Bound field however if I make this an unbound field the Sigma sign won't show in the header of the collumn.
I added a test project. If you run this you will see three fields:
1) Description
2) Total amount as a Bound field
3) Total amount as a Unbound field (Not the possibility to use the summary!)
It seems that the field data isn't being recognized as Numeric data?
How can I solve this problem/Is there a workaround.
Patrick.
Works great.
HI Patrick,
Add this line of code to AddFieldToDataGrid:
if (isUnbound)
field.Label = fieldName + " Unbound";
field.Settings.EditAsType = typeof(double);
else
field.Label = fieldName + " Bound";
Sincerely, MattDeveloper Support Engineer
