645
Display multiple series in XamDataChart
Hi There,
I want to display TickData(FinancialPriceSeries) and FillData(ScatterSeries) on same DataChart. X-Axis has timestamp and Y-Axis has price value. Here is the part of code
public class TickDataPoint
        public int Index { get { return _index; } set { if (_index == value) return; _index = value; OnPropertyChanged("Index"); } }
        public double Open { get { return _open; } set { if (_open == value) return; _open = value; OnPropertyChanged("Open"); } }
        public double High { get { return _high; } set { if (_high == value) return; _high = value; OnPropertyChanged("High"); } }
        public double Low { get { return _low; } set { if (_low == value) return; _low = value; OnPropertyChanged("Low"); } }
        public double Close { get { return _close; } set { if (_close == value) return; _close = value; OnPropertyChanged("Close"); } }
        public double Volume { get { return _volume; } set { if (_volume == value) return; _volume = value; OnPropertyChanged("Volume"); } }
        public DateTime Date { get { return _date; } set { if (_date == value) return; _date = value; OnPropertyChanged("Date"); } }
public class FillDataPoint : ObservableModel
        public double FillPrice { get { return _fillPrice; } set { if (_fillPrice == value) return; _fillPrice = value; OnPropertyChanged("FillPrice"); }}
        public DateTime Date{get { return _date; }set { if (_date == value) return; _date = value; OnPropertyChanged("Date"); }}
        public string Side{get { return _side; }set { if (_side == value) return; _side = value; OnPropertyChanged("Side"); }}
public class DataCollection
        ObservableCollection<TickDataPoint> _tickDataPoints = GetTickData();
        ObservableCollection<FillDataPoint> _fillDataPoints = GetTradeData();
<ig:XamDataChart x:Name="PriceChart" Legend="{Binding ElementName=PriceLegend}" Margin="5" VerticalZoomable="True" HorizontalZoomable="True" Grid.Row="1" >
                <ig:SyncManager.SyncSettings>
                    <ig:SyncSettings SyncChannel="syncDynamicCharts"
                                         SynchronizeHorizontally="True"
                                         SynchronizeVertically="False" />
                </ig:SyncManager.SyncSettings>
                <ig:XamDataChart.Axes>
                    <ig:CategoryXAxis x:Name="DateXAxis"  Label="{}{Date:HH:mm:ss}">
                        <ig:CategoryXAxis.LabelSettings>
                            <ig:AxisLabelSettings Location="OutsideBottom" Extent="30" Visibility="Collapsed" />
                        </ig:CategoryXAxis.LabelSettings>
                    </ig:CategoryXAxis>
                    <ig:NumericYAxis x:Name="PriceYAxis" >
                        <ig:NumericYAxis.LabelSettings>
                            <ig:AxisLabelSettings Location="OutsideLeft" Extent="55" />
                        </ig:NumericYAxis.LabelSettings>
                    </ig:NumericYAxis>
                </ig:XamDataChart.Axes>
                <ig:XamDataChart.Series>
                    <ig:FinancialPriceSeries x:Name="TickDataSeries" Title="Stock Price" DisplayType="Candlestick"
                                             OpenMemberPath="Open" CloseMemberPath="Close" HighMemberPath="High" LowMemberPath="Low"                                 VolumeMemberPath="Volume"
                                 XAxis="{Binding ElementName=DateXAxis}"
                                             YAxis="{Binding ElementName=PriceYAxis}">
                    </ig:FinancialPriceSeries>
                    <ig:ScatterSeries x:Name="FillDataSeries" MarkerType="Circle"
                                  XMemberPath="Date" YMemberPath="FillPrice"
                    </ig:ScatterSeries>
                </ig:XamDataChart.Series>
            </ig:XamDataChart>
I tried
TickDataSeries.DataContext = _dataCollection.TickDataPoints;
FillDataSeries.DataContext = _dataCollection.FillDataPoints;
And
TickDataSeries.ItemSource = _oneTickDataModel.TickDataPoints;
FillDataSeries.ItemSource = _oneTickDataModel.FillDataPoints;
How can I bind two different Observable collection to these two different series of same chart?
Please let me know.
Thanking you in advance for your help.
Nasir
