We use the xamDataTree 2012.2 with <ig:NodeLayout.ExpandedIconTemplate> and CollapsedIconTemplate. Now the tree runs fine except the displayed Icons are not clickable (like it is in the MS TreeView), I only can click to the node caption(s) to select one. But: if I don't have a caption, how do I select the node?
Any simple solution like a property "NodeIconClickable = true" ?
TorstenR
Hello Torsten,
Thank you for your reply. Please let me know if you need any further assistance on the matter.
Sincerely,
Krasimir
Developer Support Engineer
www.infragistics.com/support
This is a solution, but only the half way: the hover effect should also be applied if the mouse goes over.
So I think the best is to have this:
<ig:NodeLayout.ItemTemplate>
<DataTemplate>
<StackPanel Orientation="Horizontal"><Image .../><TextBlock ... />...
So we have the click handling AND the hover effect.
Thank you for your email. I have been looking into your question and I can suggest using the MosueMeftButtonDown event of the root item in the icon templates, in order to select the node, when you click on it. I have created a sample application for you, that shows how you can implement this approach.
