We have number of fields for XAMDataGrid where first field contains an EditButton. And remaining are from my ViewModel Object.
I need to display a panel which contains number of controls for editing the selected DataItem. That panel should be immediatly after the selected Item. Can you suggest me with some solution for this. A sample code will help me more.
Thank you.
Account Number
Name
Details
Location
Edit
1111
Test1
Test1 test 1
Hyderabad
Some controls with above data to Edit. And also Save and Cancel Buttons for saving and cancelling. After Save/Cancel I need to close this panel.
2222
Test2
Test2 Test2
New York
3333
Test3
Test3 Test3
London
Satya
S
Hello Satya,
I have tested the sample with 2290 release and it doesn’t work, but I also tested it with the latest service release of 10.3 (2337) and everything works correctly, so I can suggest you download it by logging to our web site and going to Account \Keys & Downloads.
Hi Stefan,
Its not working after installing service release 2010.3.2290. Assembly version 10.3.20103.2290.
Tested with version 10.3.20103.1003, Its working fine. All of my projects are using 2010.3.2290. Could you please suggest me to resolve this issue.
Satya.
Thanks again.
Thank you Stefan. Its working fine.
I have tested the sample against version 10.3 and .NET 4 and everything seems to work ok on my side. I have attached a video showing the functionality implemented in the sample.
