75
Simple XamDataPresenter sample code gives an exception
I just installed NetAdvantage 2012.2 WPF and tried the following simple example code in a XAML UserControl with namespace defined as shown:
xmlns:igDP="http://infragistics.com/DataPresenter"
<igDP:XamDataPresenter Grid.Row="0" Name="xamDataPresenter1" BindToSampleData="True" />
The project targets .Net 4.  I get the following exception in the VS2010 XAML designer, but the code compiles and runs fine:
System.Reflection.TargetInvocationException
Exception has been thrown by the target of an invocation.
   at System.RuntimeMethodHandle._InvokeMethodFast(IRuntimeMethodInfo method, Object target, Object[] arguments, SignatureStruct& sig, MethodAttributes methodAttributes, RuntimeType typeOwner)
   at System.RuntimeMethodHandle.InvokeMethodFast(IRuntimeMethodInfo method, Object target, Object[] arguments, Signature sig, MethodAttributes methodAttributes, RuntimeType typeOwner)
   at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture, Boolean skipVisibilityChecks)
   at System.Delegate.DynamicInvokeImpl(Object[] args)
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
System.ArgumentException
'{DependencyProperty.UnsetValue}' is not a valid value for the 'Infragistics.Windows.DataPresenter.RecordPresenter.TemplateCardView' property on a Setter.
   at System.Windows.Setter.Seal()
   at System.Windows.SetterBaseCollection.Seal()
   at System.Windows.Style.Seal()
   at System.Windows.StyleHelper.UpdateStyleCache(FrameworkElement fe, FrameworkContentElement fce, Style oldStyle, Style newStyle, Style& styleCache)
   at System.Windows.FrameworkElement.OnStyleChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at Infragistics.Windows.DataPresenter.RecordPresenter.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
   at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
   at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
   at System.Windows.DependencyObject.InvalidateProperty(DependencyProperty dp)
   at System.Windows.FrameworkElement.UpdateStyleProperty()
   at System.Windows.FrameworkElement.OnInitialized(EventArgs e)
   at System.Windows.FrameworkElement.TryFireInitialized()
   at System.Windows.FrameworkElement.ChangeLogicalParent(DependencyObject newParent)
   at System.Windows.FrameworkElement.AddLogicalChild(Object child)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.InternalAddLogicalChild(Object child)
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.InitializeGroupByRecordCache()
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.InitializeCachedCellArea()
   at Infragistics.Windows.DataPresenter.Internal.TemplateDataRecordCache.VerifyCache()
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.VerifyFieldLists()
   at Infragistics.Windows.DataPresenter.VirtualizingDataRecordCellPanel.MeasureOverride(Size availableSize)
   at System.Windows.FrameworkElement.MeasureCore(Size availableSize)
   at System.Windows.UIElement.Measure(Size availableSize)
   at MS.Internal.Helper.MeasureElementWithSingleChild(UIElement element, Size constraint)
   at System.Windows.Controls.ContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureOverride(Size constraint)
   at System.Windows.Controls.Control.MeasureOverride(Size constraint)
   at System.Windows.Controls.DockPanel.MeasureOverride(Size constraint)
   at System.Windows.Controls.Grid.MeasureCell(Int32 cell, Boolean forceInfinityV)
   at System.Windows.Controls.Grid.MeasureCellsGroup(Int32 cellsHead, Size referenceSize, Boolean ignoreDesiredSizeU, Boolean forceInfinityV)
   at Infragistics.Windows.Controls.CardPanel.MeasureOverride(Size availableSize)
   at Infragistics.Windows.DataPresenter.RecordPresenter.MeasureOverride(Size availableSize)
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateNextElement(Boolean isHeader)
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateHeader(FieldLayout fl, Record attachedToRecord)
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateScrollableRecords()
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.GenerationCache.GenerateAllRecords()
   at Infragistics.Windows.DataPresenter.GridViewPanelFlat.MeasureOverride(Size availableSize)
   at System.Windows.Controls.ItemsPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollContentPresenter.MeasureOverride(Size constraint)
   at System.Windows.Controls.ScrollViewer.MeasureOverride(Size constraint)
   at Infragistics.Windows.DataPresenter.RecordListControl.MeasureOverride(Size availableSize)
   at System.Windows.Controls.Border.MeasureOverride(Size constraint)
   at Infragistics.Windows.DataPresenter.DataPresenterBase.MeasureOverride(Size constraint)
   at MS.Internal.Designer.ZoomableViewPresenter.DesignerBackground.MeasureOverride(Size constraint)
   at Microsoft.Windows.Design.Interaction.DesignerView.MeasureOverride(Size constraint)
   at MS.Internal.Designer.Viewport.MeasureOverride(Size availableSize)
   at System.Windows.Interop.HwndSource.SetLayoutSize()
   at System.Windows.Interop.HwndSource.set_RootVisualInternal(Visual value)
   at MS.Internal.DeferredHwndSource.ProcessQueue(Object sender, EventArgs e)
Bill
