95
Editing Cells Through Key Presses
While the xampivotgrid currently goes into edit mode on a mouse click. I'm interested in setting the cells into edit mode when you hit a number key. During KeyPreviewDown I check if the pressed key was a number key and if the cell is not already in edit mode. If both these are true, I call MoveEditCell and pass in the currently selected/active cell. The problem that I have encountered is that when I open the cell for edit this way, the cell is opened and the inside value is selected. I want to append the numbers they type to the end of the held value, not overwrite it and replace it with the values they type.
Basically, I need to open the cell for edit, deselect the digits, and move the spot where they're typing to the end of the value that is already in there.  How would I go about this? Thanks for any advice.
