I have templated the cell value with my own control. Need to show grid lines for all of the grid cells? I tried to give border thickness and BorderBrush as suggested in another post. Did not work, suggestions
<Style TargetType="{x:Type ig:CellValuePresenter}">
<Setter Property="BorderThickness" Value="0,0,1,1"/>
<Setter Property="BorderBrush" Value="Black"/>
<Setter Property="Template"> <Setter.Value> <ControlTemplate>
<TextBlock/>
</ControlTemplate> </Setter.Value> </Setter> </Style>
Hello Jasvinder,
Thank you for your post. I have been looking into it and I can suggest you use the following Style instead of yours:
<Style TargetType="{x:Type igDP:CellValuePresenter}"> <Setter Property="Template"> <Setter.Value> <ControlTemplate> <Border BorderBrush="Black" BorderThickness="0,0,1,1"> <TextBlock/> </Border> </ControlTemplate> </Setter.Value> </Setter> </Style>
Because when you set the Template of a Control you lose all of its built-in functionality.
Hope this helps you.
