3590
How to make vertically stacked graphs line up?
I have 3 graphs stacked vertically and using the SyncManager. Each graph is bound to series' on both the left and right side. The problem I run into is that occasionally there is no data for a series so the y axis limits are not set and therefore no labels are displayed.  In that case the major x axis lines do not line up perfectly across the 3 graphs. I have tried setting the Extent property of the left and right y axis but this does not seem to work. Is there a way to force the spacing/size of the y axis when there are no labels?
I have attached a screenshot of what I am talking about. The graphs are set to the same limits and if all y axes had ranges displayed they line up correctly. I need to account for when not all axes will be available.
Please let me know if this makes sense.
