I have a ContentPane with a Command_CanExecute handler that is context specific, but the same command is availabe in the MainWindow with the XDM. If e.CanExecute is false in the ContentPane, I don't want that same command to be executable in the MainWindow either. I assumed e.Handled = true in the ContentPane would keep the event from bubbling, but apparently it is bbubling, because when e.CanExecute == false in the ContentPane and e.Handled == true, the command can execute in the MainWindow (the MainWindow has no Command_CanExecute, making the command always executable. I added a Command_CanExecute to the MainWindow but the command was still executable).
When the command cannot execute in the ContentPane, how can I also block it in the MainWindow? Thanks.
Hello Darryl,
I am checking if this is still an issue for you.
If you require any further assistance please do not hesitate to ask.
I am attaching a sample application(DockManagerContentPaneCommand.zip) where I am using a Command for adding additional menu item of the context menu of a content pane. It will be great, if you can modify it.
I'll go ahead and give you credit since I over-simplified the description of the scenario, and a sample is a bit more than I have time for right now. But I believe this is more related to the key gestures. Thanks.
That would be great. I'll get one to you over the weekend for you to look at next week.
If you can provide a sample that demonstrates the issue I can take a look to see if there is something you can do or if there is something that we can change to accommodate it.
