I have a XamGeographicMap with one GeographicShapeSeries showing the world map (using the ShapeFiles/world from the wpf sample application). If I set the map to show Markers for all the shapes (nations in the world), then the displayed markers are automatically positioned in the correct location of the map. If, however, I try to programmatically show symbols using a GeographicSymbolSeries, the displayed symbols are in the wrong location on the map.
I am using the following to determine the location of the symbols:
var series = new GeographicSymbolSeries();series.LongitudeMemberPath = "Longitude";series.LatitudeMemberPath = "Latitude";series.MarkerCollisionAvoidance = Infragistics.Controls.Charts.CollisionAvoidanceType.None;
// For each shape in my shape file, add a symbol to the symbol series using the first geographic point of the shape.// THIS IS INCORRECT: the symbol ends up in a different location than the corresponding marker. QUESTION: how does the map compute the location of the marker??
var x = item.Points[ 0 ][ 0 ].X; // WRONG ???var y = item.Points[ 0 ][ 0 ].Y; // WRONG ???
My map displays several ShapeSeries at the same time:
Layer 1 (bottom): world shapefile.Layer 2: usa states shapefile.Layer 3: usa counties shapefile.Layer 4 (top): my symbols.
My shapes have a solid color Fill.
If I enable markers for each ShapeSeries, markers at lower z-order are completely obscured by markers displayed at higher z-order layers (due to the solid color Fill).To overcome this problem, I created my own SymbolSeries at the top-zorder, so that my symbols would always be visible.
HI ,
Can you please address this question:
Why do you need to use the SymbolSeries instead of using the markers of the ShapeSeries?
Sincerely,
Matt Developer Support Engineer
HI,
Calculating the X/Y Coordinates for the symbols based on a closed polygon can hurt performance.
Sincerely, Matt Developer Support Engineer
Thanks for the reply.
Unfortunately, that link only shows how to position the symbols using "hard-coded" locations.I am trying to position the symbols at the same locations that the map itself would use if it was displaying markers.
For example, if I use the following XAML (no code behind):
<UserControl x:Class="InfragisticsMapTester.Views.TestMarkerLocation" xmlns="http://schemas.microsoft.com/winfx/2006/xaml/presentation" xmlns:x="http://schemas.microsoft.com/winfx/2006/xaml" xmlns:mc="http://schemas.openxmlformats.org/markup-compatibility/2006" xmlns:d="http://schemas.microsoft.com/expression/blend/2008" xmlns:ig="http://schemas.infragistics.com/xaml" mc:Ignorable="d" d:DesignHeight="300" d:DesignWidth="300"> <UserControl.Resources> <ig:ShapefileConverter x:Key="shapefileConverterWorld" ShapefileSource="ShapeFiles/world.shp" DatabaseSource="ShapeFiles/world.dbf" /> </UserControl.Resources> <Grid> <ig:XamGeographicMap BackgroundContent="{x:Null}"> <ig:XamGeographicMap.Series> <ig:GeographicShapeSeries ItemsSource="{StaticResource shapefileConverterWorld}" ShapeMemberPath="Points" MarkerType="Automatic" MarkerCollisionAvoidance="None" ToolTip="{Binding Item.Fields[CNTRY_NAME]}" /> </ig:XamGeographicMap.Series> </ig:XamGeographicMap> </Grid></UserControl>
The map will end up displaying the world shapefile, and it will automatically display markers over thecenter of each nation. (See attached file MapWithMarkers.jpg)
For my particular application, I don't want to use the automatic Markers. I want to use my own symbol series,but I want to position a symbol at the center of each nation on the map, located in the same place that the marker wouldhave been placed. I don't know how to programmtically compute the requires symbol locations.
Does that make sense?
Here a link that may help you resolve your issue:
http://help.infragistics.com/NetAdvantage/WPF/Current/CLR4.0/?page=xamGeographicMap_Binding_Geographic_Data_Models.html
