Similar to conditional formatting. Can't figure out how to set a read-only state at the row level instead of the column level.
Not optimal but it works. Thanks. I should put in a feature request.
I have been looking into your question and we do not provide a built-in functionality for making a record read-only. You can achieve this behavior by handling the ‘EditModeStarting’ event of the XamDataGrid and checking the value of the specific field and cancelling the event like e.g. :
private void xamDataGrid1_EditModeStarting(object sender, Infragistics.Windows.DataPresenter.Events.EditModeStartingEventArgs e)
if (e.Cell.Record.Cells[1].Value.ToString() == "Z4" || e.Cell.Record.Cells[1].Value.ToString() == "Ram")
e.Cancel = true;
If you need any further assistance on this matter, feel free to ask.
