Hello --
I have a xamdatagrid and allowing the user to group on any column. One column, "type" is what I want displayed when they group on that column, but I want to it to be grouped by using a different value, typeID. So... user drags "Type" column to group by area, users sees "Type" groupings (while behind the scenes it actually grouped on TypeId. Yes, I expect the same "Type" to be listed more than once.
This does not seem to work:
Grid_Grouping(object sender, GroupingEventArgs e) {
int index = e.Groups.ToList().FindIndex(x => x.FieldName == "Type");
if (index != 1) e.Groups[index] = new FieldSortDescription("TypeID", Ascending, true); } }
Hello Daniel,
Thanks again.
Thanks for the quick reply Stefan! This works as you say and resolves my issue! I forgot about the GroupByEvaluator! :)
Cheers!
Thank you for your post. I have been looking into it and I created a sample project for you with the fucntionality you want. Basically I used custom GroupByEvaluator where the grouping of City Field is based on Princode Field. Please let me know if this helps you or you need further assistance on this matter.
