1830
Using a custom autocomplete textbox
I'm using a customer autocomplete textbox (http://wpfactb.codeplex.com) in XamTextEditor EditTemplate (v12.1), and all is working fine except when I use the tab key to navigate to the next cell, the autocomplete's dropdown doesn't close.  It does close when I click on the next cell.  I realize I'm not giving you much info about the autocomplete control, but can you think of anything I might be doing wrong using the following EditTemplate:
<Style TargetType="igEditors:XamTextEditor">
    <Setter Property="Template">
    </Setter>
    <Setter Property="EditTemplate">
        <Setter.Value>
            <ControlTemplate TargetType="igEditors:XamTextEditor">
                <actb:AutoCompleteTextBox x:Name="PART_FocusSite" BorderThickness="0" MaxLength="50">
                    <actb:AutoCompleteTextBox.AutoCompleteManager>
                        <actb:AutoCompleteManager>
                            <actb:AutoCompleteManager.DataProvider>
                                <local:PartDataProvider/>
                            </actb:AutoCompleteManager.DataProvider>
                        </actb:AutoCompleteManager>
                    </actb:AutoCompleteTextBox.AutoCompleteManager>
                </actb:AutoCompleteTextBox>
            </ControlTemplate>
        </Setter.Value>
    </Setter>
</Style>
  • 1830
    Verified Answer
    You may consider this closed unless you have a recommendation for an excellent autocomplete textbox.  I lucked out in making what appears to be an innocuous change to the source code of the custom (not "customer") control from the link above.
