1865
Field ordering od Active layout
I am copying xamDataGrid's data to excel. I am doing it field by field. In order to do so, I have the following loop:
foreach (Field field in xamDataGrid.DefaultFieldLayout.Fields)
However, the ordering of the fields in xamDataGrid.DefaultFieldLayout.Fields is different from what is visible in the grid. Is there a way to ensure that the fields are copied to excel in the same order as the currently active layout. I guess, something like:
foreach (Field field in xamDataGrid.CurrentFieldLayout.Fields) ..... so, if the user has moved some fields around, the new field ordering is used.
Thanks.
