625
Cannot Center Cell Content
I have a custom control that contains a XamDataGrid (v10.3).  AutoGenerateColumns = false and fields are dynamically and added to a FieldLayout that is then assigned as the DefaultFieldLayout.  All fields bind to numeric properties of business objects.  I have tried the following to center the content in my grid's cells:
From code:
            foreach (Field fld in myControl.myXamDataGrid.DefaultFieldLayout.Fields)
                fld.Settings.CellValuePresenterStyle = new Style(typeof(CellValuePresenter));
                fld.Settings.CellValuePresenterStyle.Setters.Add(new Setter(CellValuePresenter.HorizontalContentAlignmentPropertyHorizontalAlignment.Center));
From XAML (UserControl.Resources):
        <Style TargetType="{x:Type igDP:CellValuePresenter}">
            <Setter Property="HorizontalContentAlignment" Value="Center"/>
            <Setter Property="HorizontalAlignment" Value="Center" />
        </Style>
None of these approaches are working. Any ideas?
Paul
  • 138253
    Hello Paul,
  • 138253
    Thank you for your post. I have been looking into it and I can suggest you create a Style for the XamNumericEditor and set its HorizontalContentAlignment Property to Center, since your values are numeric. It can be defined like this:
    <Style TargetType="{x:Type igEditors:XamNumericEditor}">
    </Style>
    Please let me know if this helps you or you need further assistance on this matter.
