Here is the code I'm currently using:
<igDP:Field Name="DwellTime" Label="Dwell Time (Hrs)" Width="80"> <igDP:Field.Settings> <igDP:FieldSettings> <igDP:FieldSettings.EditorStyle> <Style TargetType="{x:Type igEditors:XamTextEditor}"> <Setter Property="Format" Value="0.00" /> <Setter Property="HorizontalContentAlignment" Value="Right" /> </Style> </igDP:FieldSettings.EditorStyle> </igDP:FieldSettings> </igDP:Field.Settings> </igDP:Field>
What I want to get is if the value is .75, it will show up as 0.75 which works fine. The underlying value type is either an int or a double. The issue is that I need a blank row where 0 is blank. I'm not sure how to get there and any suggestion is welcomed.
Thank you,
Mike
HI,
If you want to show blanks when the value is zero, you can use a converter.
I am attaching a sample application.
Sincerely,
Matt
Developer Support Engineer
Anybody?
