I defined two summary definitions with different custom summary calculators. I want them to appear both above the same field and among each other within the summary record. If I set PositionFieldName-Property to the same name one hides the other.
OK, I think for now I can live with the workaround. Thank you.
mwicke said: Second, the property is called DATARecordSizingMode, so why is it affecting summary records?
Let me know if I can provide any further assistance.
Hello Duane,
I really don't believe this behavior is expected and still think it's a bug.
"When using the SizedToContentAndFixed or SizedToContentAndIndividuallySizable values for this property there is a negative impact to performance when rendering the grid because the control must calculate the size of each individual cell"
http://help.infragistics.com/NetAdvantage/WPF/2012.2/CLR4.0/?page=InfragisticsWPF4.DataPresenter.v12.2~Infragistics.Windows.DataPresenter.FieldLayoutSettings~DataRecordSizingMode.html
A workaround seems to be setting the DataRecordSizingMode to IndividuallySizable?!
mwicke said: Hello Duane, thanks for the sample. I now figured out, why in my situation the settings you used did not work. The problem is "DataRecordSizingMode" is set to "Fixed" in the FieldLayoutSettings. But this behaviour is a bug, isnt't it?
I think the behavior is expected since setting the value to Fixed there is a performance gain. How about setting this property to SizedToContentAndFixed?
