Hi there,
i have a small project with a DataGrid where one field is a CheckBoxColumn.
i set the CheckBox in the Column with the following Style in code behind:
UnboundField checkfield = new UnboundField(); ControlTemplate controltemplate; string xamlControl = "";
xamlControl = @" <ControlTemplate xmlns:x=""http://schemas.microsoft.com/winfx/2006/xaml"" xmlns=""http://schemas.microsoft.com/winfx/2006/xaml/presentation""> <CheckBox HorizontalAlignment=""Center"" IsChecked=""{Binding Attributes[Used]}"" VerticalAlignment=""Center""/> </ControlTemplate>";
byte[] xmlControl = Encoding.ASCII.GetBytes(xamlControl); MemoryStream stream = new MemoryStream(xmlControl); controltemplate = (ControlTemplate)XamlReader.Load(stream); Setter templateSetter = new Setter(CellValuePresenter.TemplateProperty, controltemplate); Style checkboxcell = new Style(typeof(CellValuePresenter)); checkboxcell.Setters.Add(templateSetter); checkfield.Settings.CellValuePresenterStyle = checkboxcell;
Everything is working fine and now i come to my problem.
i need to read every record in the grid and extract the boolean IsChecked-Value of the CheckBoxColumn for each record.
How do i handle this?
regards
Cloud
Hello Cloud,
Thank you for your post. I have been looking into it and I can suggest you use the following code in order to get the ActiveRecord’s CheckBox value:
CellValuePresenter cvp = CellValuePresenter.FromRecordAndField(xamDataGrid1.ActiveRecord as DataRecord, xamDataGrid1.FieldLayouts[0].Fields["name or index of the UnboundField"]); CheckBox cb = Utilities.GetDescendantFromType(cvp, typeof(CheckBox), true) as CheckBox;
Please let me know if this helps you or you need further assistance on this matter.
Cloud Strife said: Hi there, i have a small project with a DataGrid where one field is a CheckBoxColumn. i set the CheckBox in the Column with the following Style in code behind: UnboundField checkfield = new UnboundField(); ControlTemplate controltemplate; string xamlControl = ""; xamlControl = @" <ControlTemplate xmlns:x=""http://schemas.microsoft.com/winfx/2006/xaml"" xmlns=""http://schemas.microsoft.com/winfx/2006/xaml/presentation""> <CheckBox HorizontalAlignment=""Center"" IsChecked=""{Binding Attributes[Used]}"" VerticalAlignment=""Center""/> </ControlTemplate>"; byte[] xmlControl = Encoding.ASCII.GetBytes(xamlControl); MemoryStream stream = new MemoryStream(xmlControl); controltemplate = (ControlTemplate)XamlReader.Load(stream); Setter templateSetter = new Setter(CellValuePresenter.TemplateProperty, controltemplate); Style checkboxcell = new Style(typeof(CellValuePresenter)); checkboxcell.Setters.Add(templateSetter); checkfield.Settings.CellValuePresenterStyle = checkboxcell; regards Cloud
i tried another way:
UnboundField checkfield = new UnboundField(); checkfield.Name = ""; checkfield.Settings.EditorType = typeof(XamCheckEditor); checkfield.Settings.EditAsType = typeof(bool); Style editorStyle = new Style(typeof(XamCheckEditor)); Setter styleSetter = new Setter(XamCheckEditor.IsCheckedProperty, dictionary["Used"]); editorStyle.Setters.Add(styleSetter); checkfield.Settings.EditorStyle = editorStyle; checkfield.Settings.AllowEdit = true; checkfield.Width = new FieldLength(50); grid.FieldLayouts[0].Fields.Add(checkfield);
this works as good as the other way. But now i have the problem that if i want to get the Value of the cell where my checkbox is in, the value is null.
i noticed that i have to edit one time so that the value of the cell is filled with true or false. but i need that the value is loaded at the first loading of the window.
please help me asap
cloud
