225
XamMaskedInputAutomationPeer InvalidValueBehavior
I have a XamNumericInput with ValueConstraints and InvalidValueBehavior="RevertValue".  When I test this control in my application, it works as expected, reverting the value back if I tried to violate the constraints.  However, I am also testing this control using its automation peer, XamNumericInputAutomationPeer.  There, I set the value by getting PatternInterface.IValuePattern from the peer and calling SetValue.  There, I can see the value is also getting set but it does not revert back to the previous value if I violate the constraint.  Is this a bug? Am I setting the value through the peer incorrectly?
  • 5600
    Did you try to remove the focus from the input control, so it can revert its correct value back? I test this with xamNumericInput(not editor) and it seems to work fine - when remove the focus the correct value is reverted back.
    Anastas
