We have several issues which are related with CategoryDateTimeXAxis.First issue is unproper position of the labels in some situations. All the lines and series key points is positioned in proper place, but labels are positioned on different scales, sometimes even outside of the control border.
Second issue is related to the size of the labels in some situations. Seems of all if the first two items is positioned close one to another it's trim it's size. But in all others place where a lot of space for the label it's also trimmed.
Full-size pictures are attached. We use 11.1 version of controls.
What is possible solutions or approach to solve this issues?
Hello Andrey,
We have shipped out a new service release where your issue is resolved. I'd be glad to find out if you had tested it out and if it had met your requirements.
You can download the Service Releases by logging to our web site and going to Account \Keys & Downloads.
I have logged this with development under ID: 124845 and I have also created a support ticket on your behalf: CAS-102537-W6H2G9 and have linked the development issue to it, so that you can get automatically updated, when a Service Release containing the fix is available for download. You can get the new version from our website’s “My IG”, “My Keys & Downloads” tags: https://es.infragistics.com/Membership/Default.aspx?panel=Downloads#Downloads
You can also monitor the support ticket’s progress through the “My Support Activity” tag: https://es.infragistics.com/Membership/MySupport.aspx
Hello Stefan,
As you requested, I'm sending two examples with bugs described in the first post. These errors reprodused with versions of components 11.1 and 12.1. I hope that these examples will be enough and you will find a quick solution.
Thank you for your post. I have been looking into it, but it seems like that I am missing something in your scenario, so if this is still an issue for you, could you please send an isolated sample project, where the issue is reproduced, so I can investigate it further for you.
