1830
Cancel ContentPaneCommands.Close
When executing ContentPaneCommands.Close, the handler for the closing event of the pane can cancel the event.  I need to know if there is a way to dig out the cancellation of that event from the code that executes ContentPaneCommands.Close, which returns a boolean that is not related to cancellation of the Closing event.
              void Window_Closing(object sender, CancelEventArgs e)
                   foreach (var pane in dockManager.GetPanes(PaneNavigationOrder.VisibleOrder))
                        pane.ExecuteCommand(ContentPaneCommands.Close);
                  // need ability to detect cancellation  from Closing event below and issue e.Cancel = true here
               void Pane_Closing(object sender, PaneClosingEventArgs e)
                     // for whatever reason ...
                    e.Cancel = true;
