Is there a function that will give me all selected records? I want to avoid doing a foreach loop for datarecord.IsSelected
Thanks this is what I needed.
I can try to use the XamDataGrid's property - SelectedItems. It contains two properties Reocrds and Cells which return the selected records or cells.
Hope this helps you.
Anastas
