I am using XamDataChart v12.1.
I want certain functionalities in XamDatachart.
1) According to the image attached and marked as 1, I want to display the CategoryXAxis label as in image. For this, I have changed CategoryXAxis label Angle to -45 and Extent = 100 but it displays the label over the plotarea and not according to the image.
2) According to the image attached and marked as 2, I want to have a small line to show the value associated with this axis value.
3) According to the image attached and marked as 3, I want to have dotted lines for gridlines of plotarea.
Please help me in having these functionalities implemented.
Thans,
VJ
Hello Arun,
The labels on the second image are displayed like this, because there are labels for every data point shown by the chart. Setting the Extent property displays the labels on two levels, in order the labels to be shown properly. You can set the Interval property of the CategoryXAxix to 2. This way a label would be shown for every second data point. On other possible solution is to set Width for the Grid and wrap it with a ScrollbarViewer. Atfer wripping the grid inside the viewer you have to set the visibility for the two scrollbars as follows: HorizontalScrollBarVisibility="Auto" and VerticalScrollBarVisibility="Auto". Please let me know if you have any further questions.
Hello Gergana,
Thank you very much for your quick response. Please find attached image in which i have added two DataCharts, below one is produced by the given sample and upper one i required.
I have been investigating your issue. After the investigation I have modified the sample you have sent. In the sample I have changed the value of the CenterX and CenterY properties in the template for the label. I have set the Extent property for the AxisLabelSettings. Please refer to the modified sample and feel free to let me know if you require any further assistance on the mater.
Hi Gergana,
I used your given sample which is working fine but the problem is only that its cutting XAxis Label when there are large number of DataPoints. For full clearification I have modified your given sample according to my requirment. Please find the attached sample. For more clearification kindly see my previously image post.
I am just checking your progress on the issues. If you require any further assistance please do not hesitate to ask.
