We have an application that uses nested tabbed contents, which is taking up too much real-estate. Is there a way to make the border around a tabbed docked window smaller?
I am just checking if you got this worked out or you still require any assistance or clarification on the matter.
Thank you. I can't verify at the moment, but will verify and post back w/in a few days. Crazy here at the moment.
Thank you for your post. I have been looking into it and I can suggest you add the following Style for the TabGroupPane:
<Style TargetType="{x:Type igDock:TabGroupPane}"> <EventSetter Event="Loaded" Handler="TGPloaded"/> </Style>
And this event handler in the code behind:
private void TGPloaded(object sender, RoutedEventArgs e) { (Utilities.GetDescendantFromName(sender as DependencyObject, "ThickInnerBorder") as Border).BorderThickness = new Thickness(0); //this one here is the inner Border var ad = Utilities.GetDescendantFromType(sender as DependencyObject, typeof(AdornerDecorator), true); ((ad as AdornerDecorator).Child as Border).BorderThickness = new Thickness(0); }
Please let me know if this helps you or you need further assistance on this matter.
