380
Unhandled Exception
I'm getting an unhandled exception from the xamDataChart, it's pretty random but it seems to happen most often when I switch the data series that the chart is to display.  Basically when the operator requests to see a different set of values, I clear the chart series and recreate a new set of series to display.  This is the info I am getting from the exception.  Looking at the inner exception it looks like the chart is trying to set the height of something to infinity?
Exception Details
    Message
            Exception has been thrown by the target of an invocation.
    Types
            System.Reflection.TargetInvocationException
    Call Stack
            at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
            at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
            at System.Delegate.DynamicInvokeImpl(Object[] args)
            at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
            at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
    Target
            mscorlib
Target
            InvokeMethod
        Message
                'Infinity' is not a valid value for property 'Height'.
        Types
                System.ArgumentException
        Call Stack
                at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
            at Infragistics.Controls.Charts.ColumnSeries.RenderFrame(CategoryFrame frame, CategorySeriesView view)
            at Infragistics.Controls.Charts.CategorySeries.RenderSeriesOverride(Boolean animate)
            at Infragistics.Controls.Charts.Series.DoRenderSeries(Boolean animate)
            at Infragistics.Controls.Charts.ContentInfo.DoRefresh()
            at Infragistics.Controls.Charts.ChartContentManager.DoRefresh()
        Target
                WindowsBase
Target
                SetValueCommon
