Hi, I need to make some colmuns aligment to left based on the value of other column (language code e.g fi-FI, en-US, ar-SA -> right alignment).
Can I do it with binding or do I have to do it in code behind. I have a lot of rows (thousands) so I can not loop them in code behind or grid gets really slow?
Is it posible to do some kind of fast value converter? I know I can create style like
<Style TargetType="{x:Type igEditors:XamDateTimeEditor}" >
<Setter Property="HorizontalAlignment" Value="Left" />
<Setter Property="HorizontalContentAlignment" Value="Left" />
</Style>
Br,
Mauri Korhonen
Hello Mauri,
Really glad this worked out for you.
You can verify as answered so other community users can better benefit from the post.
Really NICE! This is exactly what I meant and was looking for. I got it implemented based on this example and works really well!! Thanks :D Job well done...
Mauri
I have been looking into your requirement and I can suggest you create a style for the XamDateTimeEditor with a Converter like this one:
<local:StringToAlignmentConverter x:Key="con" />
<Style TargetType="{x:Type igEditors:XamDateTimeEditor}">
<Setter Property="HorizontalContentAlignment" Value="{Binding Path=Record.DataItem.Currency, ConverterCulture=en-US, RelativeSource={RelativeSource AncestorType={x:Type igDP:CellValuePresenter}}, Converter={StaticResource con}}" />
where:
Currency is the property containing the language code and
public class StringToAlignmentConverter : IValueConverter
public object Convert(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
if (value.ToString() == "ar-SA")
return HorizontalAlignment.Right;
else return HorizontalAlignment.Left;
public object ConvertBack(object value, Type targetType, object parameter, System.Globalization.CultureInfo culture)
throw new NotImplementedException();
Please let me know, if you require any further assistance on the matter.
