I have a grid that I'm trying to create using the XamGrid control. Everything works fine except when I turn AutoGenerateColumns to false, it doesn't load at all. I've triple checked that my object property matches the field name exactly. It still has nothing. Any ideas? Here's my xaml.
<ig:XamGrid x:Name="test" ItemsSource="{Binding Path=MyList, IsAsync=True}" Height="Auto" MinHeight="150" Width="Auto" MinWidth="500" AutoGenerateColumns="False" > <ig:XamGrid.PagerSettings> <ig:PagerSettings AllowPaging="Top" PageSize="500"/> </ig:XamGrid.PagerSettings> <ig:XamGrid.ColumnLayouts> <ig:ColumnLayout Key="ObjectKey"> <ig:ColumnLayout.Columns> <ig:TextColumn x:Name="fieldName" Key="Name" Width="Auto" HeaderText="Person Name"/> </ig:ColumnLayout.Columns> </ig:ColumnLayout> </ig:XamGrid.ColumnLayouts> </ig:XamGrid>
Thank you for your post. I have been looking into it and the code you have provided and I can suggest you see this link from our online documentation:
http://help.infragistics.com/NetAdvantage/WPF/2012.1/CLR4.0/?page=xamGrid_Manually_Defining_a_Basic_Column_Structure.html
where it is explained how to define Column layouts for flat data and here you can see the procedure for hierarchical data:
http://help.infragistics.com/NetAdvantage/WPF/2012.1/CLR4.0/?page=xamGrid_Defining_Hierarchical_Layouts.html
Please let me know if this helps you or you need further assistance on this matter.
Can a mod delete this post? The forum threw an error constantly every time I posted this, then suddenly decided to take all my attempts. No idea why.
(It's still doing it BTW. I'll get an error when I hit post but it's going to go through)
