Is it possible to remove the minimised tiles altogether. i.e. have maximised and normal modes only?
Regards
S
I have been looking into your issue. I have been testing this issue and I was not able to reproduce this issue. Would you please modify the sample application I have attached in my previous post with the functionality you are using, so it shows the issue. this way I would be able to reproduce the issue and provide you with further support.
Thank you for the cooperation. Looking forward to hearing from you.
I know that it's an old post, but I try to do the same.
Your solution is correct if you have less than 30 Tiles.
Because other Tile seems to not be loaded in memory and the event StateChanged is not fired (for this one).
Have you a suggestion?
Because ohter Tile seems to not be loaded in memory and the event StateChanged is not fired.
Hello Simon,
Thank you for your post. I have been investigating your issue. After the investigation I have created a small sample for you. In this sample I set an event, TileStateChanged, which watches if some of the tiles have changed their state and if they have the other tiles are being closed. Please find the attached sample and feel free to contact us if you have any further questions.
Thank you for your response
Its not that i don't want minimized tiles, i just don't want to see them. I want normal tiles or one maximised tile which i can take out of that state back to normal tiles. Can this be done?
