2325
Drag & Drop Highlight entire row when dragging from source in XAM Data Grid.
Hi team,
I have the implementation of Drag & Drop b/w two XAMDatagrids as below in xaml
 <UserControl.Resources>
<Style TargetType="{x:Type igDP:CellValuePresenter}">
<Setter Property="Background" Value="Transparent"/>
<Setter Property="BorderBrush" Value="Transparent"/>
<Setter Property="BackgroundHover" Value="Transparent"/>
<Setter Property="BorderHoverBrush" Value="Transparent"/>
<!--<Setter Property="BackgroundActive">
<Setter.Value>
<LinearGradientBrush StartPoint="0,0" EndPoint="0,1">
<GradientStop Offset="0" Color="#FF85A2B2"/>
<GradientStop Offset="1.1" Color="#00FFFFFF"/>
</LinearGradientBrush>
</Setter.Value>
</Setter>-->
<Setter Property="BorderActiveBrush" Value="#00151C55"/>
<Setter Property="BackgroundSelected">
<Setter.Value>
<GradientStop Offset="0" Color="#FFCAEBFF"/>
<GradientStop Color="#83CAEBFF" Offset="1"/>
</Setter.Value>
</Setter>
<Setter Property="BorderSelectedBrush" Value="#FF666666"/>
<Setter Property="BackgroundFieldSelected">
<Setter.Value>
<GradientStop Offset="0" Color="#FFDDDDDD"/>
</Setter.Value>
</Setter>
<Setter Property="BorderFieldSelectedBrush" Value="#FF666666"/>
<Setter Property="BackgroundPrimary" Value="#7FE9E9E9"/>
<Setter Property="BorderPrimaryBrush" Value="#FFE9E9E9"/>
<Setter Property="ForegroundStyle">
<Setter.Value>
<Style/>
</Setter.Value>
</Setter>
<Setter Property="ForegroundActiveStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" />
<Setter Property="ForegroundAlternateStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" />
<Setter Property="ForegroundPrimaryStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" />
<Setter Property="ForegroundSelectedStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" />
<Setter Property="ForegroundFieldSelectedStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" />
<Setter Property="ForegroundHoverStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" />
<Setter Property="CornerRadius" Value="0"/>
<Setter Property="BorderThickness" Value="0"/>
<Setter Property="Padding" Value="2,0,0,0"/>
<Setter Property="VerticalContentAlignment" Value="Center"/>
<!-- AS 5/23/07 BR23120 -->
<Setter Property="HorizontalContentAlignment" Value="Stretch"/>
<Setter Property="Template">
<Setter.Value>
<ControlTemplate TargetType="{x:Type igDP:CellValuePresenter}">
<igWindows:CardPanel MouseDown="CardPanel_MouseDown" >
<ig:DragDropManager.DragSource>
<ig:DragSource IsDraggable="True" DragChannels="ChannelA"
Drop="DragSource_Drop" DragOver="DragSource_DragOver"
DragStart="DragSource_DragStart" />
</ig:DragDropManager.DragSource>
<ig:DragDropManager.DropTarget>
<ig:DropTarget DropTargetMarkerBrush="Red" />
</ig:DragDropManager.DropTarget>
<!-- [JM 06-06-07] This element is not being used so I am commenting it out. Its Visibility property is initialized to Collapsed and the IsSelected
trigger below has commented out the line that sets the Visibility to Visible. Checked with Grant on this and he feels it is left over
from early styling efforts and can be removed. -->
<!--<Rectangle x:Name="LeftBorder"
Fill="#FFBBBBBB"
Width="1"
Margin="0,1,0,0"
HorizontalAlignment="Left"
VerticalAlignment="Stretch"
Visibility="Collapsed" />-->
<Border
x:Name="MainBorder"
CornerRadius="{TemplateBinding CornerRadius}"
BorderThickness="{TemplateBinding BorderThickness}"
BorderBrush="{TemplateBinding BorderBrush}"
Background="{TemplateBinding Background}"/>
<Rectangle
x:Name="Active"
Fill="{TemplateBinding BackgroundActive}"
HorizontalAlignment="Stretch"
Width="Auto"
Height="Auto"
SnapsToDevicePixels="True"
Opacity="1"
StrokeThickness="1"
Stroke="{TemplateBinding BorderActiveBrush}"/>
<ContentPresenter
x:Name="PART_EditorSite"
HorizontalAlignment="{TemplateBinding HorizontalContentAlignment}"
VerticalAlignment="{TemplateBinding VerticalContentAlignment}"
Margin="{TemplateBinding Padding}"
Style="{TemplateBinding ForegroundStyle}"
</ContentPresenter>
</igWindows:CardPanel>
<ControlTemplate.Triggers>
<!-- HighlightAsPrimary -->
<Trigger Property="HighlightAsPrimary" Value="true">
<Setter Property="Background" Value="{Binding Path=BackgroundPrimary, RelativeSource={RelativeSource Self}}"/>
<Setter Property="BorderBrush" Value="{Binding Path=BorderPrimaryBrush, RelativeSource={RelativeSource Self}}"/>
<Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundPrimaryStyle, RelativeSource={RelativeSource TemplatedParent}}"/>
</Trigger>
<!-- IsFieldSelected -->
<Trigger Property="IsFieldSelected" Value="true">
<Setter Property="Background" Value="{Binding Path=BackgroundFieldSelected, RelativeSource={RelativeSource Self}}"/>
<Setter Property="BorderBrush" Value="{Binding Path=BorderFieldSelectedBrush, RelativeSource={RelativeSource Self}}"/>
<Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundFieldSelectedStyle, RelativeSource={RelativeSource TemplatedParent}}"/>
</Trigger>
<!-- IsSelected -->
<Trigger Property="IsSelected" Value="true">
<Setter Property="Background" Value="{Binding Path=BackgroundSelected, RelativeSource={RelativeSource Self}}"/>
<Setter Property="BorderBrush" Value="{Binding Path=BorderSelectedBrush, RelativeSource={RelativeSource Self}}"/>
<Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundSelectedStyle, RelativeSource={RelativeSource TemplatedParent}}"/>
<!--<Setter Property="Visibility" Value="Visible" TargetName="LeftBorder" />-->
</Trigger>
<!-- IsActive -->
<Trigger Property="IsActive" Value="true">
<Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundActiveStyle, RelativeSource={RelativeSource TemplatedParent}}"/>
<Setter Property="Visibility" TargetName="Active" Value="Visible"/>
</Trigger>
<!-- IsMouseOver -->
<MultiTrigger>
<MultiTrigger.Conditions>
<Condition Property="IsMouseOver" Value="True"/>
<Condition Property="IsSelected" Value="False"/>
<Condition Property="IsFieldSelected" Value="False"/>
</MultiTrigger.Conditions>
<Setter Property="Background" Value="{Binding Path=BackgroundHover, RelativeSource={RelativeSource Self}}"/>
<Setter Property="BorderBrush" Value="{Binding Path=BorderHoverBrush, RelativeSource={RelativeSource Self}}"/>
<Setter TargetName="PART_EditorSite" Property="Style" Value="{Binding Path=ForegroundHoverStyle, RelativeSource={RelativeSource TemplatedParent}}"/>
</MultiTrigger>
<!-- Field.IsFixedStateChanging JM 01-22-09 NA 9.1 FixedFields -->
<DataTrigger Binding="{Binding Path=Field.IsFixedStateChanging, RelativeSource={RelativeSource Self}}" Value="True">
<Setter Property="Background" Value="#AA8DBAEB"/>
<Setter Property="BorderBrush" Value="#AA8DBAEB"/>
</DataTrigger>
<!--SSP 5/27/09 NAS9.2 IDataErrorInfo Support-->
<Trigger Property="IsDataErrorTemplateActive" Value="true">
<Setter TargetName="PART_EditorSite" Property="ContentTemplate" Value="{DynamicResource {x:Static igDP:DataPresenterBase.DataErrorContentTemplateKey}}" />
</Trigger>
</ControlTemplate.Triggers>
</ControlTemplate>
</Setter.Value>
</Setter>
<Style.Triggers>
<!-- DRCA Foreground Hover Trigger-->
<!-- JJD 4/30/09 - TFS17157 use new IsRecordSelected property -->
<Trigger Property="IsRecordSelected" Value="True">
<Setter Property="ForegroundStyle" Value="{DynamicResource {ComponentResourceKey {x:Type igDP:XamDataGrid}, GrayForegroundStyle}}" />
</Trigger>
<!-- DRCA Foreground Selected Trigger-->
<!-- JJD 4/30/09 - TFS17157 use new IsMouseOverRecord property -->
<Trigger Property="IsMouseOverRecord" Value="True">
</Trigger>
</Style.Triggers>
</Style>
</usercontrol.resources>
My Events in the Code behind are as follws.
DataRecordPresenter dp;
DataRecordPresenter dragOver;
private void DragSource_DragStart(object sender, Infragistics.DragDrop.DragDropStartEventArgs e)
dp = Utilities.GetAncestorFromType(e.DragSource as DependencyObject, typeof(DataRecordPresenter), false) as DataRecordPresenter;
private void DragSource_Drop(object sender, Infragistics.DragDrop.DropEventArgs e)
dragOver = Utilities.GetAncestorFromType(e.DropTarget as DependencyObject, typeof(DataRecordPresenter), false) as DataRecordPresenter;
ComponentList targetElement = dragOver.DataRecord.DataItem as ComponentList;
ComponentBase sourceElement = dp.DataRecord.DataItem as ComponentBase;
viewmodel vm = dragOver.DataPresenter.DataContext as viewmodel ;
// My Business logic  continues
int overIndex;
private void DragSource_DragOver(object sender, Infragistics.DragDrop.DragDropMoveEventArgs e)
overIndex = dragOver.Record.VisibleIndex;
My requirement is   i should highlight entire row when i start dragging.
