I have attached the sample application which is already implemented the wrap text for the cells and user can also change the row height for the rows.
I found one problem for the wrap text and change row height and you can reproduce it by following steps:
1.Make sure the cells are in wrap text mode(the style is implemented)
2.Decrease the height of the row by using mouse until some characters are cut(not shown totally)
3.Increase the height of that row in step2 and you will found the characters are still not shown totally.
Is there a way to fix this?
Thank you!
I have succeeded in reproducing the issue and it seems that it is already fixed. I can suggest you download our last service : Infragistics website -> My Account -> Select your product -> Select Service Release to download it.
If you need any further assistance on this matter, feel free to ask.
The sample is correct.
Now I attach the status of the first row height.
You could see it:
1.Decrease the row height into the image "DecreaseHeight.png" by using mouse on bottom border of the any column of the first row
2.Increase the row height into the image "IncreaseHeight.png"
I hope you will see the problem from the sample application.
Please attach the correct sample application.
Mabe i use the wrong sample.
If so, I will upload a correct one and the right sample will display all cells with string text not number.
Hi, you need to decrease the height of the row until it can't be decreased.
Thank you
Could you please try it again?
