I have formatted couple of Columns within the XAMDataGrid using the following Feature
<Style TargetType="{x:Type igEditors:XamNumericEditor}"> <Setter Property="Mask" Value="nnn,nnn,nnn,nnn.nn"/> <Setter Property="NullText" Value="-" /> </Style>
However when I export the Grid to Excel, the formatting of number is lost for e.g. the comma's go missing. Also huge numbers like 150000000000 are displayed as 1.5E+11. Numbers with decimal places as XXX.00 are displayed as XXX. When we manually change the format on the excelsheet to number, the value displayed is as desired.
I am not able to manually export each row and each column as the Grid might have grouping which we wish to have in the same format while export to excel.
Can you please help me with this?
Hi Abbas,
I just received a little more information from our development team about this product idea. For now we are not considering implementing it and this should be done by the provided approach earlier in this thread.
In WPF application we can put various themes and styles with triggers that change the look of various elements, etc. They are applied to elements that are virtualized so we don’t have a way to determine on which non viewable elements have to apply styling in order to export it.
I hope this helps.
Hi Abbas
I will update you if I have more information about this feature.
Thank you for using Infragistics and participating in the development of the product by providing your feedback.
Hi again,
Thank you for the prompt response. Looking forward to see this feature in coming releases.
I understand your scenario and I have research this furthered and I have opened for you a product idea -PI12080147. I have sent your product idea directly to our product management team. Infragistics continues to monitor application development for all of our products so as trends appear in requested features, we can plan accordingly. If your feature is chosen for development you will be notified at that time.
Please let me know if you have any furthered questions or you need more assistance on this.
If there is no further recommendation, please say so!
