Is there a way to style the cells of the Excel style FilterUI? They appear too close together and use the default system highlighting.
One clarification. The highlighting was easily set through a simple style. However, to set the highlighting, I had to create an entire template!! Setting the style for the TreeView.ItemContainerStyle did not work. Not sure if this is a problem with the default style of the control (which seems to operate straight on the border control in its template through a setter in the same template.) However, I have this same scenario outside of an infragistics control, and there when I set the TreeView.ItemContainerStyle, I get tweak the highlighting without any issue.
Another odd issue I noticed is unless the style is declared within the resources of the XamDataPresenter/Grid, when initially viewing the control, the style doesn't take effect. The custom style only takes effect after re-opening the control. Seems odd.
Hello masterianvii,
I am glad that you resolved your issue. I believe that other community members may benefit from this.
Your suggestion worked. I created a general style for TreeViewItem in the scope of my control and was able to set the padding/highlighting there.
Thanks!
I am just checking your progress on the issue.
If you require any further assistance please do not hesitate to ask.
Thank you for your feedback. I can suggest you set new template in order to style the checkboxes in the filter menu.
Please let me know if you need any additional assistance.
