I have field Songname, which can be A, B or C, and field TrackNumber that can be -5 to 5. Now I want to sort as follows:
Now I see its possible to apply a custom comparer on a single field, or apply simple sorting on multiple columns, but what I need to do is create a comparer that receives the entire record object (or at least these two fields), and then sorts based on the combined value of the two fields. How do I do this?
If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
Hello Neil,
I have been looking into your requirement and I can suggest you create a hidden UnboundField, that would be bound to the whole record object and you can use your custom Comparer on it. I have created small sample project for you so you can see what I mean (Grid_wholeRecordSorting.zip). Please note that the comparer I created does not specifically follow your description, but rather only shows how multiple properties can be used.
Please let me know if you require any further clarification on the matter.
