I'm using XamDataGrid 11.2 on my solution.
This is a big solution with a multiple projects and on every project I have several XamDataGrids.
I want to create one general ExportToExcel method using the ExcelCellFormatSettings, ExcelGroupFormatSettings and the ExcelLabelFormatSettings to edit the visual appearance of the excel tables.
My problem is that I want to define the visual appearance only once in my solution and not in every Window/UserControl separately.
I tried to create a style for the XamDataGrid in my ResourceDictionary, but I'm getting this error massage:
" 'Cannot create unknown type '{http://infragistics.com/ExcelExporter}DataPresenterExcelExporter'.'"
Even if I will be able to create this style, every xamDataGrid that overwrite the FieldSettings will "lose" the visual appearance setting that sets in the style.
Is there a good solution for this? Maybe I'm using this wrong…
Hello Roy,
It has been a while since you have made your post, in case you still need support I will be glad to assist you further. I suppose the other community members can benefit from this answer as well. I have been looking into your post and I created a sample project for you with the functionality you want. Basically I added a class library to the solution, where I created a FiledSettings instance, which can be used in all projects. If you want to set different settings to the Fields, you can set them directly to the Field, not the XamDataGrid.
