Plamen, I'm trying to implement the gross profit aggregator I found here:http://blogs.infragistics.com/forums/p/64405/326542.aspx
I also looked at this thread for examples:http://community.infragistics.com/forums/p/45131/248927.aspx#248927The above thread has a link to another sample. This link does not work:http://samples.infragistics.com/sldv/RunSamples.aspx?cn=pivot-grid#/pivot-grid/flatdata-aggregators
I can get the aggregator to work however the grid shows data. In the attached zip, click the "Toggle Measure" button.
Thank you Plamen it works.
Hi Sam,
It seems that the specified cast (decimal to double) in Evaluate method is not valid because the instances of IAggregateable you process there operate over the properties of type decimal.
After I've fixed the cast I can see the data in the grid.
Plamen.
