80
Loosing Styles on Floating Panels
I have an application that has a mixture of Panels defined in XAML as well as a number that I dynamically add on demand.
My problem is that when I only use the statically defined Panels the application starts and on drag/undock the correct styling is applied to the floating panels. When I dynaamically create panels during startup the styles are no longer used when the panel floats.
I am sure that I am missing some "magic" code here to set the styles (although I wonder why default styles are not automatically used in this case).
My styles define a custom chrome for the floating windows and use UseOsNonClientArea=false to achieve this.
Does anything spring to mind out there?
Graham
