615
How to display multiple line series in chart from simple data collection in code behind?
I'm working with the Xam Data chart and styling the  line series. I'm using sample data from code behind. The question is, how can I add more series (lines) to the chart using ObservableCollection fro the SimpleDataCollection?
{    public class SimpleDataCollection : ObservableCollection<SimpleDataPoint>
        public SimpleDataCollection()
            this.Add(new SimpleDataPoint() { Label = "1", Value = 4.0 });
            this.Add(new SimpleDataPoint() { Label = "2", Value = 3.0 });
            this.Add(new SimpleDataPoint() { Label = "3", Value = 2.0 });
            this.Add(new SimpleDataPoint() { Label = "4", Value = 7.0 });
            this.Add(new SimpleDataPoint() { Label = "5", Value = 4.0 });
            this.Add(new SimpleDataPoint() { Label = "6", Value = 9.0 });
    /// <summary>
    /// Simple storage class for pair of string and double value
    /// </summary>
    public class SimpleDataPoint
        public double Value { get; set; }
        public string Label { get; set; }
The Xaml code for the chart is this:
                <ig:XamDataChart x:Name="Test_Trend_Chart" HorizontalZoomable="True" HorizontalZoombarVisibility="Visible" VerticalZoombarVisibility="Visible" VerticalZoomable="True" WindowRect="0,0,1,100" Margin="0" Style="{DynamicResource XamDataChartStyleTester}" Height="284.4">
                    <ig:XamDataChart.DataContext>
                        <local:SimpleDataCollection/>
                    </ig:XamDataChart.DataContext>
                    <ig:XamDataChart.Axes>
                        <ig:CategoryXAxis x:Name="xmXAxis" ItemsSource="{Binding}" Label="{}{Label}" MajorStroke="#7F000000" MajorStrokeDashArray="1 2" >
                            <ig:CategoryXAxis.LabelSettings >
                                <ig:AxisLabelSettings Location="OutsideBottom" Extent="30" Foreground="Black" FontSize="12" />
                            </ig:CategoryXAxis.LabelSettings>
                        </ig:CategoryXAxis>
                        <ig:NumericYAxis x:Name="xmYAxis" FontFamily="Tahoma" MinorStrokeThickness="0.7" MajorStrokeDashArray="1 2" Stroke="#FFF11B1B" StrokeThickness="0" StrokeDashArray="1 2" >
                            <ig:NumericYAxis.ActualTickmarkValues>
                                <ig:LinearTickmarkValues/>
                            </ig:NumericYAxis.ActualTickmarkValues>
                            <ig:NumericYAxis.LabelSettings >
                                <ig:AxisLabelSettings Location="OutsideLeft" Extent="25" FontSize="12" TextAlignment="Right" />
                            </ig:NumericYAxis.LabelSettings>
                        </ig:NumericYAxis>
                    </ig:XamDataChart.Axes>
                    <ig:XamDataChart.Series>
                        <ig:LineSeries ValueMemberPath="Value" Thickness="3" MarkerType="None"
                            XAxis="{Binding ElementName=xmXAxis}"
                            YAxis="{Binding ElementName=xmYAxis}" />
                    </ig:XamDataChart.Series>
                </ig:XamDataChart>
  • 27093
    If the above suggestion helped you solve your issue please verify the thread as answered so other users may take better advantage of it.
  • 27093
    Suggested Answer
    Hello cgreenberg,
    I have been looking into this and usually there isn’t much to it you just add another LinesSeries instance to your Series collection. If you want to have different line paths for the two (or more) Series you would have to provide for the XamDataChart’s DataCintext property either collection of items that have two (or more) numeric properties:
        public double Value2 { get; set; }
    So that you can use different ValueMemberPaths:
    <igChart:XamDataChart.Series>
        <ig:LineSeries ValueMemberPath="Value2" Thickness="3" MarkerType="None"
    </igChart:XamDataChart.Series>
    The other approach would be to set different collections to your Series’ ItemsSource properties.
    Please let me know if you require any further clarification on the matter.
