Hi team,
in the attached image when i am trying to give minimu value to 2012 and unit =1 chart in xaxis is not displaying the chart ,
i need chart will display from starting point in x-ais
regards
Raj
I hadn’t heard back from you and I was wondering if you had further questions.
I should have given you this piece of information before concerning the xamDataChart. For the xamDataChart in order to control the range, you use the Axis MinimumValue and MaximumValue. You can see some information concerning this here.
http://help.infragistics.com/NetAdvantage/WPF/2012.1/CLR4.0/?page=xamDataChart_Axis_Range.html
If you have any questions, please feel free to contact me.
Hi Raj,
To answer your question directly, you can modify the axis range. The following link will explain the details.
http://help.infragistics.com/NetAdvantage/WPF/2011.2/CLR4.0/?page=xamChart_Modify_the_Axis_Range.html
You may have noticed that there is no longer documentation in the current release for xamChart because we are in the process of retiring that control. You might want to look into our newer high-performance XamDataChart control by looking at the following blogs which discuss the retiring of XamChart control and the reasons for it:
http://blogs.infragistics.com/blogs/jason_beres/archive/2011/11/10/important-product-changes-and-control-retirements-in-2011-2.aspx
http://blogs.infragistics.com/blogs/kiril_matev/archive/2011/11/10/upgrading-your-charting-experience-using-xamdatachart.aspx
