I use a DocumentContentHost, containing a Splitpane. In this splitpane there is a TabgroupPane (with two tabs)
When dragging a pane out of the TabgroupPane and dropping it on the DropPreview area, I just can't find it programatically after.
I mean, using a LogicalTreeHelper, i can see that the DocumentContentHost still contains only one pane (containing the tabgrouppane with only on tabitem) and the dockManager contains one more object called "DockManagerDragHelper" but i don't think it's my pane.
Does anybody know how i could find then panes dragged out?
sincerely
Thank you very much, it works fine!
The Panes collection of the XamDockManager contains the SplitPane instances for all docked and floating split panes but only the docked ones are actually within the visual tree (and are logical descendants) of the XDM. If you want to see/enumerate the ContentPanes within an XDM you can use the GetPanes method of the XDM.
