Hello, i'm trying to do a very simple thing:
suppose I have a custom summary recalculation that takes quite some time to be evaluated.I would like to bring to the user interface a label with a "please wait" content while the grid is recalculating as soon as a groupByAreaMulti element is changed.I'm trying to intercept WHEN the calculation ends but I didn't find any method on the SummaryCalculator class that I'm implementing that tells me when the whole calculation end.As far as I'm concerned I can raise custom events in the overrided EndCalculation method that can be intercepted by the main UI thred,
I can use the xamDataGrid Grouping or Grouped events to know when the calculation starts:I can also use the xamdatagrid recordsinViewChanged to find when the grid is ready.The problem is that when i'm trying to use a simple dispatcher.invoke inside these methods to set the label content, nothing happens to the UI .
Thanks, Valerio
Hello Valerio,
This is just a follow up if you require any further assistance with this thread.
Hello famproject,
For creating a custom summary calculator you can find an example in the following help docs link: http://help.infragistics.com/NetAdvantage/WPF/2011.2/CLR4.0/?page=xamDataPresenter_Creating_a_Custom_Summary_Calculator.html.
