I Have a XamDataPresenter fill with a dataview :
XDPChAff.DataSource = DsetChAff.Tables[0].DefaultView;
I Bind this xamdatapresenter with a StactPanel :
<StackPanel Grid.Column="1" Grid.Row="1" Name="SPanSaisie" DataContext="{Binding ElementName=XDPChAff, Path=ActiveDataItem }"
And all work fine.
Now , I Want set the ActiveDataItem Automatic par program . How do ?
Tank you CaisseOdev
No. I Work with my solution.
Sincerely CaisseOdev
HI CaissevOdev,
Please let me know if you need further assistance regarding this issue.
Sincerely, Matt Developer Support Engineer
Thank You
I Stop CaisseOdev
HI CaisseOdev,
You method is not needed. If you want the DataRowView for the ActiveRecord
Use this CodeSnippet:
if (xgrid1.ActiveRecord != null) { DataRecord dr = xgrid1.ActiveRecord as DataRecord; DataRowView drv = dr.DataItem as DataRowView; MessageBox.Show(drv[0].ToString()); }
Sincerely,
MattDeveloper Support Engineer
Thank you for this link , but I want to do the opposite. Find the Item if I Know the DataRowView.
For now , I Make :
int NoItem = 0;
f
if (LuCodTier == PassCodChAff)
XDPChAff.ActiveRecord = XDPChAff.Records[NoItem];
return;
NoItem++;
MessageBox.Show("Le Code : " + PassCodChAff.ToString() + " est Inconnu !!!" + "\n" +
" Impossible dans ce CAS !!! ");
ButAbandon.Focus();
Maybe there is a better method ?
Thank you CaisseOdeV
