I have 2 scrollbar issues in my xamDataGrid. I am using the 11.2.20112.1012 version.
The first issue happens when I have just enough data to show a vertical scrollbar. If I click on the scrollbar and drag it up and down, the scrollbar disappears and some of the data are hidden. The workaround I found is to use the mouse wheel to scroll which makes the scrollbar visible again.
The second issue happens when I have more rows. Again, if I click on the scrollbar and drag it to the end, there are some rows that are not shown at the end of the grid. I have to use the down arrow or the mouse’s wheel to show the remaining data.
I tried the same scenarios with a previous version of infragistics (10.3.20103.2065) and everything works as expected.
Could you please if this is a known issue and if there is a HotFix for it? If not, do you know any workaround that I could try to get rid of my scrollbar issues?
Thanks again.
I did try the 2125 version and I could not reproduce my scrollbar issues.
Thanks for your assistance.
Thank you for your post. I have been looking into it and can suggest you download the latest service release for version 11.2 (2125) by logging to our web site and going to My IG \My Keys and Downloads. If it doesn’t helps you, could you please send me an isolated sample project, where this is reproduced, so I can investigate it further for you.
