Hello, I just downloaded the new version and have a requirement that will need me to work on the network node, i downloaded the sample files and installed it and opened it in VS 2010, when i click on the network node xaml under hte Infragistics.Web.SLDV project i get an error in the designer and is not displaying the UI.
Error Details: i get the below error. it happens only for the network nodes. I do have installed Silverlight 5 sdk as well.
I am just checking, if you need any further assistance on this matter.
In our XamFeatureBrowser there are samples that demonstrate the functionality that you are looking for :
xamNetworkNode -> Data -> GML Reader
xamNetworkNode -> Display -> Node Distance
If you need any further assistance on this matter, feel free to ask.
Well, i dont have expression blend on my computer right now, but i was trying to do this for one of my application, and the issue i am facing now is to understand the way the network node work, if i create a GML dynamically and assign it to the GML viewer can i have it working? Also how do i set the distance between the nodes dynamically. The example provided on the site wasnt that useful and i havent found any examples on the web as well.
I am just checking, if you require any further assistance on the matter.
I have been looking into your issue and it seems that this design error is due to the design capabilities of the Visual Studio because the Visual Studio is not design-oriented program environment and our sample browser application contains a lot of controls that refer to multiple styles and other resources. I can suggest you run the application using Microsoft Expression Blend because it is user interface design oriented environment.
If you need any further assistance, feel free to ask.
