When I try to load my xamdatagrid with the attached layout, I get an ArgumentOutOfRangeException. Can anyone see whats wrong with the layout?
There is already a discussion about this question here:
http://community.infragistics.com/forums/t/68533.aspx
Hi, the service release 10.1.2216 does fix the problem, but has caused another problem with the XamDataGrid.
I get the following error message "DisplayAdorningEditors can only be sent on a XamDataGrid". Its as though the Infragistics.Windows.Extensions.dll did not get updated with the service release and can no longer work with the updated XamDataGrid.
Can you help please? This is releativly urgent. Thanks
I have been looking into the sample you have sent me and I tested it with the latest service release of 10.1 and the issue no longer occurs, so I suggest you download it by logging to our web site and going to My IG \My Keys and Downloads.
Hope this helps you.
I have created a support ticket on your behalf (CAS-89805-B7GSZN) in our CHS, where you can upload your sample.
I have created a sample project but I cant upload it because the size limit is 200kb my sample project is 812kb. How should I proceed.
