605
How can I bind the XamComboEditor to a DataTable in XAML?
Hello
How can I bind the XamComboEditor to a DataTable (created in the CodeBehind-File) in XAML?
If I define it in the Code-Behind-File, it works, but how can I define it in the XAML-File?
Code-Behind:
Me.XamComboEditor1.ItemsProvider.ItemsSource = dt
Me.XamComboEditor1.ItemsProvider.DisplayMemberPath = "Name"
Me.XamComboEditor1.ItemsProvider.ValuePath = "Id"
But how does it works in the XAML-File?
 <igEditors:XamComboEditor ... >
<igEditors:XamComboEditor.ItemsProvider>
                    <igEditors:ComboBoxItemsProvider ItemsSource= ????? DisplayMemberPath="Name" ValuePath="Id" />
</igEditors:XamComboEditor.ItemsProvider>
</igEditors:XamComboEditor>
I hope, you can help me.
  • 350
    Here is what I had to do:
    XAML:
        <Window.Resources>
            <igEditors:ComboBoxItemsProvider x:Key="SiteProviderKey" ValuePath="SiteId" DisplayMemberPath="Site">
            </igEditors:ComboBoxItemsProvider>
      </Window.Resources>
    DOWN IN MY DATAGRID FIELD LAYOUT:
                            <!--Field Layout for the SiteID -->
                            <igDP:Field Name="SiteId">
                                <igDP:Field.Settings>
                                    <igDP:FieldSettings EditorType="{x:Type igEditors:XamComboEditor}">
                                        <igDP:FieldSettings.EditorStyle>
                                            <Style TargetType="{x:Type igEditors:XamComboEditor}">
                                                <Setter Property="ItemsProvider" Value="{StaticResource SiteProviderKey}" />
                                            </Style>
                                        </igDP:FieldSettings.EditorStyle>
                                    </igDP:FieldSettings>
                                </igDP:Field.Settings>
                            </igDP:Field>
     CODE BEHIND:
     Member Level Variable
            private static DataTable _dtsites = new DataTable();
     Window Load Event:
                var rsSites = (ComboBoxItemsProvider)this.Resources["SiteProviderKey"];
                rsSites.ItemsSource = (IEnumerable)_dtsites;
     Hope this helps!
    Wade
