I am using WPF 11.2.
I have a tab control with 2 tabs. Each of the tabs contain a XamDataGrid. I have a combo box with themes which can be dynamicaly set to the XamDataGrid.
My problem is when I change the theme at runtime, only the dataGrid which is in the selected tab displays the changed theme.
The dataGrid in the unselected tab still displays the old theme, although debugging into it displays that the theme was in fact changed.
I set the dataGrid's theme as dataGrid.Theme-="Generic".
Sangeetha
Hello Sangeetha,
I would like to let you know that this issue has been already fixed in the latest service release for 11.2 and 12.1 versions.
If you have any other questions with this matter please do not hesitate to contact us.
Great. Thank you for your help Ekaterina
I have logged this behavior with our developers in our tracking system, with an issue ID of 108663. I have also created a support ticket on your behalf with number CAS-88657-BL35Z1 in order to link the development issue to it so that you are automatically updated when a Service Release containing your fix is available for download.
Sincerely,
Ekaterina
Developer Support Engineer
Infragistics, Inc.
www.infragistics.com/support
currently the bug report is being processed.
Thank you for your patience.
