500
Unbound Field and DataTemplate
I have an unbound field which I'm assigning the ContentTemplate property of the CellValuePresenter to some Data Template I've defined.  How do I bind the data template to the data of the unbound field?  Currently what I've tried shows no value (blank).
This is my field:
                            <igDP:UnboundField Name="ServiceDate" Label="Service Date" BindingMode="TwoWay" BindingPath="ServiceDateUTC"
                                               Visibility="Visible" >
                                <igDP:UnboundField.Settings >
                                    <igDP:FieldSettings LabelWidth="100" CellWidth="100" AllowEdit="True"
                                                        InvalidValueBehavior="RetainValue" EditorType="{x:Type igEditors:XamDateTimeEditor}">
                                        <igDP:FieldSettings.CellValuePresenterStyle>
                                            <Style TargetType="{x:Type igDP:CellValuePresenter}" >
                                                <Setter Property="ContentTemplate">
                                                    <Setter.Value>
                                                        <MultiBinding Converter="{StaticResource IndexToTemplateConverter}">
                                                            <MultiBinding.Bindings>
        <Binding RelativeSource="{RelativeSource Self}"/>
        <Binding Path="Record.Index" RelativeSource="{RelativeSource Mode=FindAncestor, AncestorType={x:Type igDP:DataRecordCellArea}}"/>
                                                            </MultiBinding.Bindings>
                                                        </MultiBinding>
                                                    </Setter.Value>
                                                </Setter>
                                            </Style>
                                        </igDP:FieldSettings.CellValuePresenterStyle>
                                    </igDP:FieldSettings>
                                </igDP:UnboundField.Settings>
                            </igDP:UnboundField>
and this is the DataTemplate I'm assigning (through the converter):
        <DataTemplate x:Key="dateTimeTemplate">
            <igEditors:XamDateTimeEditor
                BorderBrush="Transparent"
                IsInEditMode="{Binding RelativeSource={RelativeSource AncestorType={x:Type igDP:CellValuePresenter}}, Path=IsInEditMode}"
                Value="{Binding Path=Record.DataItem.ServiceDateUTC, Mode=TwoWay, RelativeSource={RelativeSource Mode=FindAncestor, AncestorType={x:Type igDP:DataRecordCellArea}}}"
                AutoFillDate="Year" DropDownButtonDisplayMode="Always" Mask="{}{date}" />
        </DataTemplate>
