I have a grid based off a flatdatasource built from a datatable with 47 rows, 23 dimension columns and 13 measure columns.
It loads in fine but when I add more than around 10 expanded dimensions, it hits a memory exception (and this is on a 12Gb Win7 machine). I also tried adding and expanding dimensions on the Handling Large Data sample and that too broke after around 5 or 6 dimensions.
9 years old Excel 2003 can quite happily build a Pivot Table based on 65,000 rows with 20+ dimensions and 20+ measures. Can we expect this control to be able to match up on performance?
Is there a limit to the number of dimensions that can be added to a pivot grid?
Hi Rob,
Do you still require assistance on this matter?
Just following up with you to see if you've had a chance to get us that sample so we can take a look at it.
Hi
If you prefer you can mail them to my private mail: tkarkelanov@infragistics.com
RegardsTodor
Hi - yes I can, but it will take a while to put together an app that I can make public. Please wait for a few days
hi
Could you attach a sample data to see where the problem is
